Engine Number
MarkT
Engine Number
Post by MarkT »
I really need to find out engine no on my bike to identify what it is? Can you tell me where it is please? Thanks
dobbslc
Re: Engine Number
Post by dobbslc »
It's on a flat plate about 15mm x 45mm long on the top of the crankcase,
just above the clutch cover I think.
It will probably only say 1WG though.
Dobbs. :ugeek:
MarkT
Re: Engine Number
Post by MarkT »
Thanks very much!
Re: Engine Number
Post by Evilchicken0 »
Yup - unhelpfully all the 400 engines are stamped 1WG and nothing else
MarkT
Re: Engine Number
Post by MarkT »
Nope no number above clutch cover? Only number I can find is on front of engine says 1wg 998cc?
Hogdigerdy Dog
Bike owned: FZR400RR 3TJ, ZX9R fighter
Re: Engine Number
Post by Hogdigerdy Dog »
MarkT wrote:Nope no number above clutch cover? Only number I can find is on front of engine says 1wg 998cc?
as dobbslc says "It's on a flat plate about 15mm x 45mm long on the top of the crankcase just above the clutch cover"
which it is but you can't see it without having the tank off as as it's inside the frame spar on top of the crankcase
998cc that's some big bore, it's not a 3tj/Ducati hybred is it :o have you counted the cylinders ;)
MarkT
Re: Engine Number
Post by MarkT »
998 - can't even read properly now! Thanks for that, really must find out what most of the engine is!
The word Ducati makes me feel ill! After two that was enough!
