Page 1 of 2
Rear break caliper,
Posted: Thu Sep 29, 2011 12:14 pm
by Marsbar
looked through a few pages couldn't see anything, but i am blind :S
trying to unseize the pistons, got one out but couldnt get the other one out, tryed bleeding it out but didnt budge, tryed splitting the caliper and didnt budge lol.
only thing i need sorted then i can get it MoT'd
Rob
Re: Rear break caliper,
Posted: Fri Sep 30, 2011 4:16 am
by rgvsp
I feel your pain. I was doing that a couple of months ago. I used a little heat from a torch on the outside of the caliper. Then got vice grips on the lip of the piston and spun instead of trying to pull it out. Once it spun a little you can start to try to slowly lift it out. Of course the vice grips will ruin the piston.
Posted: Fri Sep 30, 2011 8:44 am
by Marsbar
yh i didnt want to use vice grips coz of damage, but looks like i wouldnt even get any grip on it anyway. was thinking split them and try and get it out then, but carnt split the fkers
Posted: Fri Sep 30, 2011 11:18 am
by lizard821000
did you try putting them back on mate then split?? much easier. you need an impact drive.
Posted: Fri Sep 30, 2011 3:56 pm
by Marsbar
lizard821000 wrote:did you try putting them back on mate then split?? much easier. you need an impact drive.
yup, they didnt budge
it ended up lifting the bike with the alan key lol :S
Posted: Fri Sep 30, 2011 4:19 pm
by rgvsp
You could always have it in a vice upside down and seriously heat the caliper with a torch and see it expands enough to loosen the piston a bit.
Posted: Fri Sep 30, 2011 5:21 pm
by Marsbar
i could heat it up, but then i wouldnt know how to pop it out without splitting it, there is no room to fit any tool around it,
if i split it then i can get a tool inside the piston like plyers but open them and pull like cirlcip plyers,
Posted: Fri Sep 30, 2011 6:28 pm
by lizard821000
here s what id do, fit them to the bike, heat the area around the bolts, then use spray some easy out stuff deep penitration stuff on the bolt after, do it a few times.....what this does is when you spray the cold fluid onto the bolt coz the caliper is hotter it gets pulled into the thread a little , deeper each time you do it....then an impact drive. id prob hit it with that off though and in a vice or somin mate, cos it might bend somin.
Posted: Sun Oct 02, 2011 4:12 pm
by Variablevalves suck
I usually pump the pistons out with the brake pedal, one will go first. I then lock this by putting a spanner down the middle of the caliper, this locks the first piston and then the second should start to move.
Posted: Mon Oct 10, 2011 1:29 pm
by Jaicen
That's what I did with mine. They're a bastard to shift any other way.
That said, apply enough heat and the seals will be ruined so they should just pull right out.
