R6 Shock 3tj
ypm25
- Bike owned: TZR250 2ma 3xv TZ250w FZR400rr
R6 Shock 3tj
Hi not even riding on the road yet but can't resist buying bits and pieces.
So I've brought an 06 R6 shock and the adaptor. Blagged an abber stand and fitted it last night, all looks good.
Only one thing worried me a bit. I used the original 400 mounting bracket at the top of the shock. The bolt diameter (bolt that fits the R6 eye) is a bit small for that bracket so I put some big washers on a wanged it up tight anyway.
Does anyone see any problems with this??
Thanks!
Thanks!
marti
Re: R6 Shock 3tj
I had the same problem, the 3tj mounting hole is 12mm dia and the r6 shock
hole and bolt is 10mm.
Kayla 850 kindly made me some spacers as i bpught my shock off her
Taggyd
Re: R6 Shock 3tj
it might not move side to side but will go up and down as weight loads and unloads. a set of top hat style washers will sort it. give kayla a pm as she already has measurements if she's done it before!
though she still owes me some spacers.....
ypm25
Re: R6 Shock 3tj
Thanks kalya is on the case!
