NC24 fuel starvation...
veefer400
Got the above happening whilst on full throttle - is fine pottering around, in town etc - will be fine for a minute then the motor die's like its run out of fuel, will pick up again if the throttle is shut for a while, altho a particulary illegal bid today caused me to coast to a halt...
The bike started fine after 10 mins, does this on reserve as well...
Im thinking the filter is blocked - can anyone tell me if it is in the wide bore pipe from the fuel tap??
(Thinking about it this has started after I refitted the small bore pipe to the fuel tap after taking the tank off to check the state of the air filter, to my mind this has never been connected whilst I have had the bike - is this some sort of vacuum pipe??)
castrol101
Re: NC24 fuel starvation...
The vacuum pipe attatches to the small bore pipe pointing directly down from the fuel tap. If the bike runs without this attatched the tap has been modded, (spring removed) so fuel flows regardless.
Drain the tank, remove the twisty (on/off/reserve) bit with a screwdriver and undo the 2 bolts holding the tap to the tank, and the fuel filter will come out as one piece attatched to the fuel tap.
If your bike does have a vacuum hose attatched ( i was'nt clear whether it did) then check if for holes all the way along, as this would cause fuel starvation especially at higher revs i believe
+1castrol101 wrote: If your bike does have a vacuum hose attatched ( i was'nt clear whether it did) then check if for holes all the way along, as this would cause fuel starvation especially at higher revs i believe
Mine had a split in it and was causing fuel starvation at higher revs.
veefer400
Im sure the vacuum pipe wasnt attached before I had the tank off to check what state the filter was in?? Found it just lying there?? Just remembered I reattached the petrol tank breather hose to the t junction halway down the side of the tank, this could also cause a vacuum in the tank if this is blocked?? Will disconnect it again before work tomoz....
veefer400
Still getting grief - have unplugged the tank breather pipe from the t-junction by the side of the pipe - will take the tank off later and check the state of the vacuum pipe.... am I right in thinking if I remove the spring out of the tap the tap will work as a normal tap and I can plug the vacuum hose??
Just seems a bit overcomplicated for a fuel tap!
fastdruid
Pretty much yes, I wouldn't though.veefer400 wrote:Still getting grief - have unplugged the tank breather pipe from the t-junction by the side of the pipe - will take the tank off later and check the state of the vacuum pipe.... am I right in thinking if I remove the spring out of the tap the tap will work as a normal tap and I can plug the vacuum hose??
I've wrecked an engine before through converting the tap to a non vacuum tap then leaving the tap on and the needle valves obviously not sealing 100% (over about 5 weeks). Filled the sump with petrol, it blew a big end bearing 9 miles later (after an oil change too).
Druid
fastdruid
Ours had issues when the end split and I cut it down slightly, the pipe ended up slightly kinked.Neosophist wrote:+1castrol101 wrote: If your bike does have a vacuum hose attatched ( i was'nt clear whether it did) then check if for holes all the way along, as this would cause fuel starvation especially at higher revs i believe
Make sure yours isn't trapped or kinked.
Druid
veefer400
SORTED!! :D
Checked the vacuum hose - all good??
Opened the tap up - to find a big split in the diaphragm....
http://i109.photobucket.com/albums/n61/ ... C02066.jpg" onclick="window.open(this.href);return false;
No wonder..... have removed the spring for the meantime, will order a new diaphragm if poss from Mr.Silver....
Mine did the same thing when I cut it down so I had to re-route it not to kink (it was a get me home from the middle of the A14) replaces all the rubber hoses after that.fastdruid wrote:Ours had issues when the end split and I cut it down slightly, the pipe ended up slightly kinked.Neosophist wrote:+1castrol101 wrote: If your bike does have a vacuum hose attatched ( i was'nt clear whether it did) then check if for holes all the way along, as this would cause fuel starvation especially at higher revs i believe
Druid
fastdruid
Yeah, that'd do it!
Druid
Druid
