Wish list almost done.
				Indiana Jones
- Bike owned: XT600Z,'10 TE250 ,XS650 chop
A set of 5 spoke Dymags should help in the looks department.
Looking forward to finding out if they make a difference to the feel of the bike.
Waiting on my RLR head to complete the package.
 [/quote]
[/quote]
 [/quote]
[/quote]-
				RoninZX-10R
Re: Wish list almost done.
Ooh, very nice!
Did you have a chance to compare the weight between the standard wheels and the Dymags?
				Indiana Jones
Picking them up next week,so will weigh them then.
I think they have been compared here before.
I picked up the rear rim when I was doing the deal,(the front was still on the bike).
Very significant difference by feel.
Track day on the 25th so I'll see how they go.
				Indiana Jones
RLR heads on the bench along with 2 incomplete engines, the bottom end of the one that dropped a valve and one doner engine. They shall become one over the winter.
The Dymags are class.
I think the bike looks good in a useful sort of way.
They really are a classy little bike.
				Indiana Jones
Getting very near completion.
http://s752.photobucket.com/albums/xx16 ... 160177.mp4
My refreshed Ohlins shock will be another step, over the weekend.
				Indiana Jones
Running and rolling. Had it up the road to check the gearbox.
All good,the VFR first gear is a new experience.
Dyno next weekend,70+ should be well possible.
Spec so far:
RLR ported and skimmed heads,slotted and dialed in cams,new rings,bearings,RLR ram air set up,close ratio VFR transmission,facet solid state fuel pump,mechanical water pump replaced with lightweight electrical booster pump(less drag),programmable CDI running stock map +2 degrees for the moment,lightweight Racing Battery(0.9kgs compared to 2.5kgs),Dymag 5 spoke wheels,Ohlins shock,RaceTech gold valved front end,ProLite front rotors,Accosatto master cylinder,modified Ganador full system.
There's more but that's all I can remember right now.
- mo haggs
- Bike owned: bikeless
oohh, i want a nosey at that.Indiana Jones wrote:Accosatto master cylinder.
you out on easter mon at kirky?
Tell me more about the close ratio VFR gearbox, what gears have been changed for what?
Cathal am i ok to come for a brew on my next visit your bike sounds like a weapon
				Indiana Jones
The first 3 gears ratios are closer than the RVF.....it's just a full low mileage NC30 transmission.Drunkn Munky wrote:Tell me more about the close ratio VFR gearbox, what gears have been changed for what?
First gear is very tall but you can hold it longer before looking for another gear.
Nothing HRC except it recommended in the RVF HRC manual.
Hopefully out in Mondello on the 1st of April and if I don't blow it up or wreck it,I'll be doing B'court and K'town over Easter.
Looking forward to getting it on track.
Pornodog,give a shout anytime. I owe you a cuppa for sorting my discs.
VFR400R RVF400
Gear ratio 1st 2.928 3.307
Gear ratio 2nd 2.166 2.352
Gear ratio 3rd 1.800 1.875
Gear ratio 4th 1.591 1.591
Gear ratio 5th 1.435 1.435
Gear ratio 6th 1.318 1.318
