Flat slides for 3TJ
MarkT
Flat slides for 3TJ
Post by MarkT »
Is this possible and where would you get a kit?
Morespeedvicar
Re: Flat slides for 3TJ
Post by Morespeedvicar »
i am prob totally wrong but dont the rrsp's have flat slides? Are you building a race bike? if not i'd stick wirth normal cv type carbs.
Ian
MarkT
Post by MarkT »
I need a set of inlet rubbers which seem to be impossible to get?
Post by Evilchicken0 »
flatslides are standard on the later SP models and yes the carb rubbers are impossible to find. stick with CVs
MarkT
Post by MarkT »
Cheers without the manifold rubbers I think I am stuck!
Kayla850
Bike owned: Sunn Tzar S2
Post by Kayla850 »
MarkT wrote:Cheers without the manifold rubbers I think I am stuck!
You're never 'stuck' ;)
Silicone sealant, rubber adhesive and electrician's tape can all be used to diagnose, bodge and repair duff carb rubbers. It's just a case of getting stuck in and doing it and failing that I'm sure something else from something else can be made to work.
www.projection-racing.com
www.pjcfasteners.com
MarkT
Post by MarkT »
Thanks, I have managed to track down some liquid rubber so I am hoping that will help!
Do the rubbers look badly cracked ???
take the carbs off again and have a look at the writing on the edge around the hole. Make a note of it and tell us what you've got.
MarkT
Post by MarkT »
No they don't look bad to me. Will post what they say!
MarkT
Post by MarkT »
A import dealer wants to look at it no too far from me, he said anything can be fixed and actually imported fzrs when they came out. I thought of putting a smaller spacer on the clamp so it so I would do up tighter! He said not to do this but what do you guys think?
