Nc23 fuel pump relay
Posted: Mon Sep 05, 2011 10:00 pm
by Willcox
Hello all just after a little information tried searching but couldn't find what I was looking for, my fuel pump relay seems faulty so I'm looking for a second hand one, the part number on it is cf322 8.9, I've seen a dew other cf322 but they've not had the 8.9 on them instead they've been all different numbers, I was just wondering if anybody would know if they would work instead?
Cheers Matt
Re: Nc23 fuel pump relay
Posted: Tue Sep 06, 2011 8:54 am
by kiwi racer
Willcox wrote:Hello all just after a little information tried searching but couldn't find what I was looking for, my fuel pump relay seems faulty so I'm looking for a second hand one, the part number on it is cf322 8.9, I've seen a dew other cf322 but they've not had the 8.9 on them instead they've been all different numbers, I was just wondering if anybody would know if they would work instead?
Cheers Matt
Any 4 pin should do mate. Just use some silicone to seal it if its a good old car model.
A Relay , is just that ..... a relay.
Posted: Tue Sep 06, 2011 7:05 pm
by Willcox
Ok cheers, how would you wire it up as I'm used to working on cars and this is a little different
Posted: Sun Sep 11, 2011 2:57 pm
by SPal
Hi wilcox
A relays just a switch !
Identify on the relay which are the coil connections and which are the contact connections.
A wiring diagram for your bike should help you identify which colour wires go to each connector
Not much more to it
SPal
Posted: Mon Sep 12, 2011 10:45 am
by GF Racing
2 low impedance triggers from the ECU - 12v in - 12v out to the pump ....
