Nc23 fuel pump relay
- Bike owned: 1989 NC23
Hello all just after a little information tried searching but couldn't find what I was looking for, my fuel pump relay seems faulty so I'm looking for a second hand one, the part number on it is cf322 8.9, I've seen a dew other cf322 but they've not had the 8.9 on them instead they've been all different numbers, I was just wondering if anybody would know if they would work instead?
Cheers Matt
Cheers Matt
- Bike owned: CBRs
Re: Nc23 fuel pump relay
Willcox wrote:Hello all just after a little information tried searching but couldn't find what I was looking for, my fuel pump relay seems faulty so I'm looking for a second hand one, the part number on it is cf322 8.9, I've seen a dew other cf322 but they've not had the 8.9 on them instead they've been all different numbers, I was just wondering if anybody would know if they would work instead?
Cheers Matt
Any 4 pin should do mate. Just use some silicone to seal it if its a good old car model.
A Relay , is just that ..... a relay.
Ok cheers, how would you wire it up as I'm used to working on cars and this is a little different
- Bike owned: 893, 929,SP1,NC29,
Hi wilcox
A relays just a switch !
Identify on the relay which are the coil connections and which are the contact connections.
A wiring diagram for your bike should help you identify which colour wires go to each connector
Not much more to it
SPal
Not much more to it
SPal
2 low impedance triggers from the ECU - 12v in - 12v out to the pump ....
Graeme France - GF Racing UK
UK Warehouse 01652 650142
GF Mobile 07778 628448
email: gfracingtw@live.co.uk
http://www.gfracinguk.com
