Spark on nc30
quinn12
- Bike owned: yamaha tzr250, honda vfr400r
Spark on nc30
Hi guys
Just a quick question?
What should the spark be on the nc30?
The spark on mine is very faint...
can inproper battery votage cause it?
- Bike owned: VFR400
Re: Spark on nc30
Checking spark by observation can be misleading. Is there a problem with how the engine runs?
amaechizzle
- Bike owned: NC35
Re: Spark on nc30
Improper battery voltage can cause a weak spark, but you would have weak everything IMHO... E.g. dim headlights, dim speedo lights etc.
Get a decent Multimeter, pull your leads and coils off, and measure their resistance's.
Check your spark plug gaps, it'll take you no more than an hour to do everything.
Are your spark plug's fitted properly, are the threads clean and earthing out correctly?
Re: Spark on nc30
you've drowned the plugs dude....
quinn12
Re: Spark on nc30
like I said in a nother post of mine, I just changed the battery and the bike started up with one touch of the starter.
