VFR400 NC30 fork problem
VFR400-NC30-SWEENEY
- Bike owned: VFR400 nc30
Hello,
I have recently noticed that their is an issue with the damper adjuster on one fork. One clicks when adjusted and the other (suspected issue fork) does not and turn a lot less than the other. Is this an easy fix or do I need a new fork top nut. I see Rick Oliver does them but they are pretty expensive! Also considering the Rick Oliver upgrade kit so taking apart is not an issue.
Re: VFR400 NC30 fork problem
Easy to remove the suspect top cap & disassemble. Once you have removed the cap, wind the spring preload adjuster fully out of the cap. You should see a ring spring & steel ball that form the "clicker", if it does not fall out first. Remove the "clicker" & wind the brass rebound adjuster out of the spring preload adjuster. You may need lots of WD40 & have to work the adjuster back & forth.
VFR400-NC30-SWEENEY
cheers mate will give it a go.
