				cam chain tensioner
				Posted: Fri Jul 22, 2011 2:18 pm
				by dt50james
				Is my cam chain tensioner manual or auto tention on the fzr400 3tj? if manual, how do you set it?
just want to make sure everything is ok.. no issues to be fair
				Re: cam chain tensioner
				Posted: Fri Jul 22, 2011 2:59 pm
				by Taggyd
				should be auto. Theres a spring that pushes on it. If it starts to rattle you can help it along with a screwdriver if needs be but it should do it itself!
				Posted: Fri Jul 22, 2011 5:36 pm
				by Hogdigerdy Dog
				as taggy said it adjusts it's self
see part number 8 on this list, the little knob on the end is spring loaded on a ratchet type affair and once it's adjusted in it won't come out again unless you take it out and put it back
http://62.5.189.98/yamahaeur/exist/moto ... .%20CHAIN/
				Posted: Fri Jul 22, 2011 5:53 pm
				by Evilchicken0
				So basically - if it isn't rattling don't fix it
