cam chain tensioner
dt50james
cam chain tensioner
Is my cam chain tensioner manual or auto tention on the fzr400 3tj? if manual, how do you set it?
just want to make sure everything is ok.. no issues to be fair
Taggyd
Re: cam chain tensioner
should be auto. Theres a spring that pushes on it. If it starts to rattle you can help it along with a screwdriver if needs be but it should do it itself!
- Hogdigerdy Dog
as taggy said it adjusts it's self
see part number 8 on this list, the little knob on the end is spring loaded on a ratchet type affair and once it's adjusted in it won't come out again unless you take it out and put it back
http://62.5.189.98/yamahaeur/exist/moto ... .%20CHAIN/
So basically - if it isn't rattling don't fix it
