The Bim
The Bim
Post by Evilchicken0 »
My Bimota is on some other forums so if you've seen it be fore then there's nothing really new here.
The Bimota SB6 is a GSXR1100WN engine put into an Italian frame; carbon / kevlar / fibregalss mix bodywork; top spec suspension (for 1995); Marchicini wheels, Bembo floating iron rich discs; lots of cnc bespoke parts. Bimota saved about 40-50kg over the basic GSXR and the bike is lower but wider than my 400 with similar wheel base
These were about £16.5k when new and were compared to the RC45 and 916R, although those were better bikes. I bought the bike quite a while ago, it was in Derry, Ireland I caught a flight over with cash in my pocket and rode it back home to London. I remember the thrill of getting off the ferry in Liverpool and seeing the U-Boat in the docks.
Since then a whole lots happened and I've kind of rebuilt it I guess, here's the list
Race cans
Race carbon exhaust heat shield
Carbon frame protectors
Carbon rearsets
Dyna coils
Silicon HT leads
Later version side stand
Original (still in the wrapper) fairing
Second hand seat unit
Replaced the seat unit cam lock
Indicators cut into the mirrors
Replaced the head lights for H4 lamps on bespoke mounting
Brembo billet calipers
Brembo billet radial master cylinder
Relocated the brake resorvior
Replaced swing arm
Samco hoses
Gix 750W cams (they have the Yoshi profile from the later spec 1100W engines
JE pistons (1146cc 12.4 comp)
Gas flowed head
Camcoated engine internals
Camcoated exhaust system
Repaired stripped and repainted inside fairing
2 bodged resprays
1 bodged engine rebuild
Dyno tune matching a set of carbs to the race and road cans
Reprofiled Kent cams, head and a JE piston where junked when an exhaust vale let go.
It puts out about 150hp with noisy cans depending on the dyno.
Still to do :
Rebuild the suspension
Fit a Dyna2000 CDI and pick up kit (the CDI has switchable maps)
Have a look at the front binicle and maybe taylor it for a small battery
Rewire it to get everything tidied up
Rework the indicators, brake and tail lights
Sort out the paint
Pictures then ...
The pics from the e-bay ad
First respray
Sketch of the tail unit for the second respay
you can see why I asked for the number to be taken off, they sprayed in the grommets and generally did a sh!t job
rebuilding
Engine problem
A month or so ago
My first trackday (about 2 weeks ago)
reverse cylinder jim
Re: The Bim
Very nice mate, i worked for a Bimota dealer when these were released.
Very underestimated bike.
Speedy
Bike owned: RVF400RR, ER6n
Re: The Bim
Post by Speedy »
Now that's dedication, going all the way up to Ireland to get the BIM!
That radiator looks capable of coping with at least 30 more ponies; it's HUUUGE!
Nicely done EC!
Well done on your first trackday too! How was it and have you booked another yet?
Re: The Bim
I haven't booked another one yet but I will. I was thinking about the PB one in Rockingham mid August.
I didn't manage to scuff my kneeslider, I wonderred what was happening the first time. Coming into the hairpins is a bit odd cos the back end locks up a bit ... I also got it wrong into a flick flack and had to run on which was anoying. I know it's really down to how you ride but I was happy when I passed a guy on a new Crossplane R1
Delboy
Re: The Bim
Post by Delboy »
Nice :drool:
A lot of work and effort gone into that I bet it makes riding it more pleasurable knowing youve put it together :peace:
shikdar_hasan
Re: The Bim
Post by shikdar_hasan »
Realy nice
hi have ever seen its one of them
Re: The Bim
These were the most sucessful Bimota with about 1100 built worldwide. There was also a later variant the SB6R which have revised bodywork and a charged airbox.
Re: The Bim
I got hold of some headers for a Gix 1100 with the veiw to use them on the Bim. It's going to need the rest of the system built up though. I'll go and see somebody who can do it later in the month.
For now though my jobs are to change the plugs, these engine eat plugs. Then put the race cans and their carbs back on. I've also got to change the headlight bulbs because one blew on dip, I've bent the bulb terminals 90 deg to get a bit more space too.
Original
Schule
Re: The Bim
Those coated pipes look the nuts, expensive?
Re: The Bim
Not really I think the downpipes come in around £150 and the cans were about £250. both are coated inside and out the cans have silver coating
