Brembo adaptor plates on nc29 fork lowers
Posted: Sun Jul 03, 2011 7:34 pm
by c7ll
Hello All,
I'm running the brembo 65mm setup on a set of nc29 fork lowers but the adaptor plates are resulting in about 5% of the outer side of each brake pad not being used.
The effect being that as the pad wears there's a lip of untouched brake pad and the bigger this gets the less braking power you have as the lip is touching before the pad meets the disc.
I bought the adaptor plates on this forum but although they fit they are clearly the wrong shape. The lower mounting hole needs to be about 5mm closer to the fork to allow the caliper to apply all of the pad.
Any suggestions on where to buy more accurate adaptor plates?
cheers,
C
Re: Brembo adaptor plates on nc29 fork lowers
Posted: Mon Jul 04, 2011 6:54 am
by Cammo
They're probably designed for bigger discs.
Posted: Mon Jul 04, 2011 9:05 am
by c7ll
I'm running nc23 discs on nc29 wheels. Any idea what discs I could get that are bigger and will fit?
Posted: Mon Jul 04, 2011 9:33 am
by amorti
c7ll wrote:I'm running nc23 discs on nc29 wheels. Any idea what discs I could get that are bigger and will fit?
I think (not sure!) that early blackbird discs would do the job. Fitment on early (carb) is different to late (injection). If I am right the PCD will be the same and they are 310mm diameter, so would make the disc about 7mm taller "into" the caliper. Not certain about offset, though.
Posted: Thu Jul 14, 2011 8:15 am
by selexon
Why don't you just machine the section of pad material away that is not getting used.
5% is not that much of a loss. I have done this on some narrow band SBK Brembo discs that where used on a std 996 set-up. couldn't feel/tell the difference.
Posted: Thu Jul 14, 2011 10:36 am
by c7ll
no worries I've managed to get a set of brackets that are the correct fit. The ones I had must be for bigger discs
Posted: Wed Aug 29, 2012 11:56 pm
by juggernaut
Where did you get the adaptor plates from?
Luke
Posted: Thu Aug 30, 2012 4:07 pm
by c7ll
Posted: Sat Sep 01, 2012 4:45 am
by GF Racing
SES ....
We stock them along with a few others.
Graeme
