Gasket
housleynick
Gasket
Post by housleynick »
Hi
Does anyone know if there is a gasket between the top and bottom crankcase, looked on micro fiche on alpha parts site but its not showing one,got a slight weep from joint at the clutch end. Is there anything that i could smear into the joint from the inside while i have the clutch side casing off.
Many thanks
Nick
