debaffled stock exhaust - stock jets - fuel mix?
jamierooney
Post by jamierooney »
Hi guys,
After debaffling my stock can, and running stock jets, should I alter the fuel mix from the stock 1.5turns on the carbs?
Have a few 100 miles to cover tomorrow and would like to get it spot on beforehand.
Cheers,
J.
stripes1976
Bike owned: 6 gk76a's, nc29
Re: debaffled stock exhaust - stock jets - fuel mix?
Post by stripes1976 »
inlet on the gsxr restricts more than the can. Do your revs drop back down quickly if rev'd or do they hold up then drop?
jamierooney
a slight hold - nothin major.
stripes1976
if your going to adjust your only looking at about an 1/8th of a turn out on each screw. you'll need the bike up to full temperature to adjust and check
morris147
Post by morris147 »
stripes1976 wrote:inlet on the gsxr restricts more than the can.
Hmmm......
Ill be getting my engine this weekend hopefully, ill give you a call when its here....
stripes1976
is your engine builder not setting it up for you rich?
