FZR 400 1WG 3EN1 Wheels .....
Finally got around with doing something with my 3EN1 front & rear ends and noticed all 3 disc's have had it ( 2 front / 1 rear ) and that the front wheel has a bump in the rim ??? It looks like someones mounted the curb straight on ???
Question is :::
Do other 400/600 fzr's share the same wheel / disc's or have I got myself another expensive greybike were parts are concerned ( Like My R1-Z ) ...
Fred.
Question is :::
Fred.
Re: FZR 400 1WG 3EN1 Wheels .....
The 3en1 and 3en2 have the same wheels ... ie 1WG and they're usually chepish. The 600 fronts have different hubs and the rear will work but the brake disk, caliper and hanger are different.
Brake discs are 285mm dia and are different from the 3en2 and 3TJ's 300mm, I think early FZR600's had these as well but check the size first.
ou could use a fzr600 front end which would drop striaght in ... but it ight get a bit pricey
