Both my tyre valves have split!? wtf
jetblack
Bike owned: '89 NC30 SEED
Post by jetblack »
Just went to top up the air in my tyres and on removing the cap the valves have both just bent over and split, pissing air out.
I suspect this may be because the previous owner sprayed the wheels with the tyres still on the rim and the paint that over sprayed onto the valves has degraded the rubber? it looks all dry and manky.
So now i need to get new valves put in both wheels :(
Anyone know how much this is likely to cost- getting the rear wheel off is going to be a pig of a job (£££), no?
edit>>>>>>>>>>>>
just read the haynes, looks like the rear wheel isn't so bad. i was imagining having to remove the swing arm. phew... :pray:
CRM
Admin NWAA
Admin NWAA
Re: Both my tyre valves have split!? wtf
Post by CRM »
with the correct sized socket and stand rear wheel is a 1 min job
front takes 10 with the correct tools.
if tyres are tired then just get a new pair at the same time, either way both tyres will need removing / refitting to get new valves.
MOT failure too
jetblack
Post by jetblack »
Nah the
tyres are fine.
porndoguk
Post by porndoguk »
buy a set of short valves off ebay, about £3
take the wheels off,
you only need to break the bead one side where the valve is and you can put a new one in,
youll just need compressed air to pop the tire back into the bead, ive done it before :)
if your local ill take them to my mates and get them done free.
update your location on your profile so any local members maybe able to offer assistance.
Rick
Sligeach
Post by Sligeach »
This came up in a topic recently.
I know when my tyres are changed by FWR in London they replace the valves with every tyre changes. I think they have a special tool to pull the valves through the hole tho?
On the receipts for the tyres they cost a pound 50
lizard821000
Post by lizard821000 »
pop both wheels off mate and head down to your local tyre place, will take them 10-15 mins to change over and long as your keeping the tyres will cost fk all. bout tenner.
jetblack
Post by jetblack »
Will do. its in with a local bike mechanic on friday for forks seals so i'll have them do it at the same time.
rob b
Bike owned: nc30
Post by rob b »
Hi.
Ye mine went the same way took the wheels off took them to my local shop £13 quid each.
Ballanced as well.
Cheers.
Rob.
lizard821000
fk thats dear! or was that to put freash rubber on too?? im guessing coz they were balenced
rob b
Bike owned: nc30
Post by rob b »
ye thats what i thought! but they only charged £3 for the valve & £10 for just takin tyre off & on.
