Rear Seat Cowling Painted
				Delboy
After a week and a big learning curve, finished painting my rear seat cowling.
Got the paint from a local paint factors, they matched it using a panel I took to them, very pleased with the match. At £10 a can I thought quite reasonably priced too, so after spraying, rubbing down with 2000 grit wet n dry, lots of water, washing up liquid and advice from you guys, here's the finished article:
[img]http://i95.photobucket.com/albums/ ... .jpg[/img]
I Got alot of satisfaction from doing it myself, it's not 100% perfect but I'm chuffed with it
				VFR400+
Re: Rear Seat Cowling Painted
Looks spot on from the pics, having done it yourself you will know off all the imperfections. But looks great from where I'm sat!
				Delboy
Looks good Del,
need to get all mine preped but i cant be arsed with the HOURS its going to take :D
				Delboy
Cheers Rick, to do just that small panel was a labour of love, lots of time and effort, to do the fairings would be a major chore
				Delboy
Rick, just had a thought, now you've got your compressor up and running, there must be an air tool you can use to 'mop' your fairings for your new scheme?
yeah ill get my act together soon need to get the CBR done for kelly before the summer if out!vfrderek wrote:Rick, just had a thought, now you've got your compressor up and running, there must be an air tool you can use to 'mop' your fairings for your new scheme?
and that might kick start me to sort the NC30 fairing early.
Needs to be a beefy compressor to run a mop properly, electric ones aint quite as good but will be better than running one off a underpowered compessor.vfrderek wrote:Rick, just had a thought, now you've got your compressor up and running, there must be an air tool you can use to 'mop' your fairings for your new scheme?
bloody nice finish there derek
 tip for the future tho, use 3M fineline tape to mask where you want curves, ie where the black curves at the front of the cowl. Get a tiny bit of heat into it and you can make some pretty tight curves with ease.
 tip for the future tho, use 3M fineline tape to mask where you want curves, ie where the black curves at the front of the cowl. Get a tiny bit of heat into it and you can make some pretty tight curves with ease.-
				lizard821000
bloody good finish that lad!
				Delboy
Cheers guys :-)
Thanks Tony I'll try that next time, flippin Harris masking tape was crap to be honest.
I got the paint matched by local paint factors and kept the paint codes so if anyone needs any let me know, they are in Wolverhampton.
