Turbo charging
Posted: Sun Jun 05, 2011 7:02 pm
by templin
im turbo`n my toy
she is a GK71F SP ive got a crank and rods from a K706 motor with its rods ive modded the gk 75 pistons my question is what ignition timing should i use ? im using the std k705 cams using k707 cam sprockets
turbo is from a hyundai and carb a 38mm ducati item
any ideas or thoughts ?
Re: Turbo charging
Posted: Sun Jun 05, 2011 8:30 pm
by stripes1976
what cams are you using, compression ratio and have you a compressor map for the turbo.
what ignition system are you using?
Re: Turbo charging
Posted: Thu Jun 09, 2011 4:23 pm
by templin
hey stripes
the pistons are GK75/76 pistons that I've machined the tip off to flaten the piston top and running double base gasket i have not as yet measured the comp
im using stock k705 cams (52hp spec) but have k706(54hp spec) cams the profile is very close but its been suggested to use the k705 items due lower lift the
sloted k706 cam sprockets are used due to crank selection and both late 706 and later motors use the 215FTH cam chain unlike the early k706 and k705 motors that use 219FTH cam chain
i dont have a turbo map for the unit and have trolled the web in search of one in terms of cdi ive got a box full to choose ive got the k705 twin pick-up (rev lim 12,500rpm) bandit gk75 (rev lim 13,500) and bandit gk75 VC i also have electronic non-advancing units so thats why im wanting to know what ign. timing to use as ive a choose of units and i could mod the cover to adjust pick-up mounts to change the base timing
Re: Turbo charging
Posted: Sat Jun 18, 2011 5:50 pm
by templin
ive decided to start the motor using non-advancing ign. units with the set std 15 degrees btdc and see how motor acts
Re: Turbo charging
Posted: Mon Jun 20, 2011 2:22 pm
by ben2306
hope you can post some pics & let me envy...
Re: Turbo charging
Posted: Mon Jun 20, 2011 11:09 pm
by stripes1976
i would be tempted to set the actuator release at about 6 psi to start but i have a feeling the turbo will be to big.
Re: Turbo charging
Posted: Mon Jun 20, 2011 11:11 pm
by stripes1976
have you got access to a dyno with det cans and do you have wideband that you can fit to your headers?
