Tokico 6 pots
Posted: Fri May 27, 2011 7:45 pm
by studlow43
Hi all,
I believe Tokico 6 pots fit the GK76A model. I've measured the hole distance which seems correct at 90mm but just wondered if the disc diameter is the same as those models that wear the 6 pots as standard? Will this matter? And do fitting them require any other mods?
Cheers.
Re: Tokico 6 pots
Posted: Fri May 27, 2011 10:51 pm
by morris147
Ive heard the 6 pots are not that good.
Re: Tokico 6 pots
Posted: Sat May 28, 2011 12:07 am
by cdegk73a
Yes, i have Tokico 6 pots on my ZX7r, they need constant attention to keep them on top form. Also, because of their relatively large size they can't dissipate heat very quickly, and have a tendency to warp discs. Funnily enough, some ZX7r owners swap their 6 pots for 4 pots from GSXr's, to avoid these issues and get a braking power increase into the bargain...
Unless your original brakes are shot, my advice is to give them a good service, and do the often neglected usual suspects.. like new fluid, pads, seals and dust seals. It can transform your brakes to as good as new. Luckily for me, a friend has stripped and cleaned my calipers for my sons GK73a, should help him stop..
Re: Tokico 6 pots
Posted: Sat May 28, 2011 7:32 am
morris147 wrote:Ive heard the 6 pots are not that good.
They are shite. Don't bother
Re: Tokico 6 pots
Posted: Sat May 28, 2011 10:14 am
by studlow43
Cheers for the advice guys!
My brakes are actually fine just heard about the "upgrade" but now i'll steer well away!!!
