Summer is looking good!
TonyB
Bike owned: NC30, CBR900RRY
Post by TonyB »
Finally got to test out my bike today (after much fiddling and money spending) and what a difference the Micron exhaust has made. It pulls strongly throughout the whole rev range with no hesitation whatsoever and it seems to have lots more power. It used to have a Tyga system but there was hesitation at 9-10k.
I have also fitted the Rick Oliver upper and lower radiators and even following the slow moving tourists in today's heat it only reached 80 degrees maximum.
I am trying to source a small fan to fit behind the upper rad for summer crawling behind the grockles (it is a Cornish thing!)
When the board is finally sorted I will post some pics and more thoughts.
Thanks for the exhaust Aly
Rick, you were right, I am not disappointed.
Ride safe you lot.
Tony
(Formally known as Lyserman)
wullvfr
Bike owned: zx9r c1
Re: Summer is looking good!
Post by wullvfr »
i dont think you will need a fan on the top rad,i have a rick lower radiator and its superb....barely gets over 80-85 and when im crawling maybe 90.....big difference from last year,the fan was always on.
thefatman
Post by thefatman »
One of my bikes which had the micron exhaust on came with 2 pc fans fixed onto the top rad with small alloy plates to hold them in place. I'm not certain if there's space behind your rad to still do that but it might be worth a try.
TonyB
Post by TonyB »
I got a GSXR1000 radiator fan off ebay for 99p and it looks small enough to go behind the top rad with a modified bracket. :geek:
Watch this space!
