digital speedo gk76a
- Bike owned: Husqvarna sm610, gsxr400 gk76
I want to change my speedo on the gk76a to a digital one, can this be done??
if so any recomendations of what speedos to use??
any help appreciated bit of a newb at all this stuff
- Bike owned: 6 gk76a's, nc29
Re: digital speedo gk76a
yes it can be done. but will need a pick up of some kind fitting for signal. And if you want to remove speedo cable and drive you will also need a spacer made.
thanks for the advicestripes1976 wrote:yes it can be done. but will need a pick up of some kind fitting for signal. And if you want to remove speedo cable and drive you will also need a spacer made.
how much do garages charge for this does anyone know??
KOSO and acewell both sell digital dashes that will work fine off your OE speedo drive.
An arm and a leg no doubt, there easy enough to do yourself mate.fewksie wrote:how much do garages charge for this does anyone know??
is there any specific model or do they all work fine??Drunkn Munky wrote:KOSO and acewell both sell digital dashes that will work fine off your OE speedo drive.
thanks for the help btw
