Lockstops
				viper_biker
Re: Lockstops
Fancy doing another one? I need one for my track bike.
				fastdruid
Re: Lockstops
That was the one and only bit of suitable aluminium I had[1].
I can give you the dimensions if you like, it's just a T piece with a few folds and one hole.
Still rather trickier than the SV lockstops I made earlier that day!
Druid
[1] From a project I did back in year 11 at school, only had it for 15 years...
Druid
				stevie
- Bike owned: 92 uk model nc30
Re: Lockstops
i driled and taped my lock stops and you can use a bolt to adjust the amount of movement you have in the steering, its best to use an allen head bolt, and its a lot easyer than having to make up a lock stop, and its adjustable.
				Gazzahh
- Bike owned: NC30 MV F4 Kwak Z900
Re: Lockstops
Hey stevie, seen the same drilled and tapped arangement on an ex manx grand prix NC30 I was working on a while ago.
				fastdruid
Re: Lockstops
I've got a NC30 set of yokes drilled and tapped that way.
I didn't want to drill these (NC35) as that weakens the stops.
The HRC manual says to do it this way although they made it in two parts and having tried to make it in one I see why, you have to bend it into place if you make it in one.
Druid
Druid
				tanuki
Re: Lockstops
good job on doing it your self looks almost exactly the same as the TYGA HRC copys,
				stevie
Re: Lockstops
drilling the stops wont weaken them enough that they would break off as the bolt will give the stops there structual integrity back when fitted, but each to there own, i works for me.
