				engine conversion question
				Posted: Sun May 01, 2011 9:07 pm
				by slowsport
				I've been reading up on the 400/600 mod and just wanted to know if the fzs600 will fit into the 3tj?
also if it does since it is a detuned thundercat engine is the fzs600 considered any better than fzr600?
thanks, slowsport
				Re: engine conversion question
				Posted: Mon May 02, 2011 9:10 am
				by cagiva996
				unfortunateley the fzs engine wont go in a 3tj as it has no mounting points on the barrels to mount to the 3tj frame spars and im sure the engine is slanted at a different angle on the fazer,though the t/cat fazer and 4jh fzr600 share alot of common parts.theres not alot of difference in performance between the fzr600 and thundercat engines (ive had both in my hybrid).the main differences are that the t/cat has stronger rods and forged pistons.ive got a 600 fazer also and it does feel a bit softer performance wise though the fazer is a bit of a fat old bus compared to a 3tj.
				Posted: Mon May 02, 2011 10:35 am
				by slowsport
				thanks cagiva
				Posted: Mon May 02, 2011 10:59 am
				by Evilchicken0
				Hey Caggiva what's the airbox like on the FZS ?
