Shim kit required.
PARUS
Shim kit required.
Post by PARUS »
Guys,
Maybe somebody know is CBR600F2 Shim kit fit to NC29
http://cgi.ebay.com/ebaymotors/HONDA-CB ... 0234328610
Or maybe somebody will recommend seller.
Thanks.
PARUS
Re: Shim kit required.
Post by PARUS »
Guys, how did you balanced your valves.. nobody bought valve kit
Matchlessman
Post by Matchlessman »
Hi Parus,
I had a mate do mine at a bike shop. He bought the shims individually based on the sizes he needed. Not sure where he got them from though.
DiscoDan
Post by DiscoDan »
Yes it looks like they'll work, the 29 uses 7.48 mm shims as do the other bikes on this list (which ironically doesn't have the 29 on it)
http://www.procycle-online.com/hotcams/valve_shims.htm" onclick="window.open(this.href);return false;
cheers
danny
PARUS
Post by PARUS »
2 DiscoDan: Thank you mate
PARUS
Post by PARUS »
Guys,
Just like double check this exactly what I need
HOTCAMS SHIM KIT
Made for all quads and bikes under 400cc's
YZ250F, WR250F, CRF250R, CRF250X, RMZ250, ECT.
Includes three 7.48mm OD valve shims of each size from 1.20 to 3.50mm in .05 increments
http://cgi.ebay.com/ebaymotors/HOTCAMS- ... 0099072414
cbr400rrn
Bike owned: NC29 CBR600F
Post by cbr400rrn »
what happens if you need four of the same size Parus? Can you not go to a local bike shop and order them that way or try Graeme France. Its gonna work out a lot cheaper than the kit that you are looking at on ebay. Just a thought
PARUS
Post by PARUS »
Good question. Especially if I will need more than 4 same size.
Here is no local bike shop selling this stuff unfortunatelly.
superlite
Bike owned: TLS, LB80 x 2
Post by superlite »
The odds of needing four shims the same size are incredibly low - you'd be more likely to win the lottery :!:
'Take it to the Back'
DiscoDan
Post by DiscoDan »
superlite wrote:The odds of needing four shims the same size are incredibly low - you'd be more likely to win the lottery :!:
Bingo! If you're ever going to do more than one shim adjustment then the full kits pays for itself. I was aghast when I paid a shop to do my last one for me, they charged $70 for 6 exchange shims (I didn't even get to keep the old ones)
cheers, d
