1996 CBR600 shock
vfr4
1996 CBR600 shock
Hello,
I've found an Ohlins shock for a 96 CBR 600 in my shed... Does anyone know if it will fit an NC23/29?
Many thanks,
Al
Many thanks,
Al
Faith, hope and cable ties...
little nick
Re: 1996 CBR600 shock
For the NC29 - it needs to be CBR600f3 - 285mm eye to eye - with a long hose on the remote reservoir. You will need to file a small indentation in the 400’s wishbone to allow access one of the rebound screw (obvious when you put it in place)vfr4 wrote:Hello,
Many thanks,
Al
sh4d0w0lf
- Bike owned: VFR400R NC24, GPZ600R
what about the nc23? what cbr600 shock would fit that?
sh4d0w0lf
forgot to ask if anyone knows how much a graeme france linkage for the nc23 would set me back?
vfr4
revved-up
I managed to install it just fine, and ground down the wishbone and it feels 10 times better... But how should the shock be set up for the weight of the 400 compared to the 6?little nick wrote:For the NC29 - it needs to be CBR600f3 - 285mm eye to eye - with a long hose on the remote reservoir. You will need to file a small indentation in the 400’s wishbone to allow access one of the rebound screw (obvious when you put it in place)vfr4 wrote:Hello,
Many thanks,
Al
Oh and where did you mount the reservoir? Mines on the exhaust hanger, but it looks untidy.
I like the way it sits under the panel on a VFR.
Thanks, Tony.
