headlight not working
robins
hi all i just got a rvf and the headlight was working but when i turned the steering from lock to lock the front lights went off, so i checked everything fuses all conectors and bulbs but couldnt find anything, but now they dont work at all the only thing i can think it may be it the relay that sits behind the clocks under a rubber hood would this possibly be shot or could it be something else, i took the rear subframe off other day could it be a conection there or a earth? any help much apreciated.
Doomah
Re: headlight not working
If the lights turned off because of you moving the bars then it's got to be a plug around that area which isn't connected, or a wire that may have snapped. Other than that all I can suggest is that you check the fusebox and, yes, the relay.
fastdruid
Is it just low beam or high and low that don't work?
Druid
Druid
Check the loom from the hi / low beam switch where it comes from the bars into the loom.
Also check the battery is being charged at aprox 14volts. Put a multi meter accross it with the engine running and rev it a bit. If the volyage goes to 16 the reg rec is knackered. That will cause a spike and can in turn burn out the headlight bulbs.
