Fitting new o rings question
Posted: Wed Apr 06, 2011 5:41 pm
by mactat2
Hi All,
fitted most of them today, just stuck on the slider guide bottom o rings :roll: how do you take the slider guides out? is there a knack?
Re: Fitting new o rings question
Posted: Wed Apr 06, 2011 10:10 pm
by Variablevalves suck
Remove the slide and the float bowl, undo the main jet one turn and push it inwards with ya thumb, repeat and the emulsion tube will start to come out of the carb into where the slide fits. Remove this and put ya fingers into the front opening of the carb and push the white plastic slide holder up and out of the top of the carb body, its very tight and if you use a screw driver etc you will fcuk it. The o'ring is under this and when you replace everything the emulsion tube only goes in one way around (theres a cut out at the bottom) its pulled back in by the main jet and only needs nipping up.
Good luck Chris.
Posted: Thu Apr 07, 2011 9:30 am
by mactat2
cheers chris your a star!
Posted: Thu Apr 07, 2011 10:03 pm
by mactat2
All done, fitted the emulsion tube o rings, surprising how easy it is when someone tells you how to do it lol
Posted: Fri May 20, 2011 2:10 am
by jfuller
Hi, im having some problems with my carbs at the moment and i suspect my o-Rings are :down: and i've no idea where to get them from. Can anyone point me in the right direction?
Posted: Wed May 25, 2011 1:32 pm
Hi mate, i do a set of o'rings for £11 posted.
Posted: Mon Sep 10, 2012 3:01 pm
by kasandrich
Just pm'd you about a set of O rings, my 400 vv starts and runs okay, but has a horribly flat spot at around 6k, it really feels like the engine is dying, its ok below 5k and get it to 7k and it pulls well, its just around the 5-6k mark.
From what I have read the O rings and a good clean sound favourite?
