fuel sender modification
Posted: Tue Mar 29, 2011 8:50 pm
by quinny-fzr4003tj
Owww'doo!
I Have a 3TJ and i've been considering taking out the existing sender unit and fitting one which wires up to a gauge as oppose to the original which somehow by magic (still cant figure it out
clever japs) drops a cylinder from firing. When you flip the switch it fires up again etc, sure you all know this anyway...But i've been riding it around with the sender unplugged to see if it makes any difference and i cant see it causing the old girl any problems........would it?
Re: fuel sender modification
Posted: Tue Mar 29, 2011 10:59 pm
by Evilchicken0
It's to tell you your low on fuel - so you flip the switch go to the garage and put some in.
Alternatively reset the trip odometer when you fill up and you'll get ... XXX amount of miles from a tank, (about 120-130 depending on the bike) until you can expect to go on reserve
Posted: Wed Mar 30, 2011 5:46 pm
by Hogdigerdy Dog
if the fuel sender is unplugged then it wouldn't cause a problem, you just won't know if your about to run out of fuel
i had the same problem myself (there's another thread somewhere in this section)
the conclusion i came to is my fuel sender is fu*ked as the reserve switch is ok when tested, so until i see a cheep one on the bay i'll continue to count the miles or in my case Km, 180Km then it's time to find a garage
Posted: Fri Apr 01, 2011 9:12 am
by quinny-fzr4003tj
thanks for the reply both :) mine works fine and does let me know when im low, i was just considering a more modern alternative....lazyness on part as my maths is terrible :D but ive decided to keep the bike as original as possible dont wanna mess with it to much
