GK71F valve adjustment
Had a bit of a problem earlier today. Was riding along as you do at about 80 and the engine started rattling terribly. Got home and took the rocker cover off to have a look at the cams only to find that the adjuster for the valve clearance on the second exhaust valve from the left was gone!
I can only assume that it's now in the sump and didn't damage the engine when it went through as it was still running rather well considdering. But now i need another one and it's proving difficult. Does anyone know if other bikes use the same adjusters? or know anywhere that might have one? Thanks, Ben.
Re: GK71F valve adjustment
Try ebay mate you might be lucky.
- Variablevalves suck
Ronbinsons foundry or if really stuck Riders of Yeovil will get them.
