brake caliper question
marty400
Hiya All,
RE:Brake Caliper Question
Man, I have opened up a can of worms here!
One of the front left brake pads is flopping around in the caliper for some reason.
There is definate movment of the pad, going up and down. Thats how I spotted the offending pad.
It is the Front left caliper. The "In Side" Pad is moving about - all the other Pads are stuck firmly in place.
OK, the pad moves up and down. This freeplay is alot more obvious than any "side to side" Movement. Is the "Up and down" movement suppose to be allowed in a caliper?!?!?!
All the other 5 pads are stuck fast in position.
My Checks so far:
(1) When I pull the Bake Lever, the movement on the Floppy Pad goes. Ie the pad is now gripped onto the Caliper. The Brake piston itself appears to be moving ok.
(2) When I let go of the Brake lever, the Brake pad floppyness comes back again. Ie. the piston appears to be moving ok.
(3) On the Offending Caliper, the "Retaining Sprung plate" is much softer than on the Other Front Caliper. I can bend the plate back a bit, away from the pads etc. Whereas the other caliper's is firmly stuck into place.
There is definate movent in the pad up and down. Thats how I spotted the offending pad.
What Do I do next guys?
Hope you can advise!
Martin
My Checks so far:
Martin
- leopard_pagan
Re: brake caliper question
there is a wee clip thing that hold the ends of the pads in place. i have had mine drop out of the callipers when cleaning.
click on the pic and look at part number 13 and part number 10. they steady the pads in place and number 13 pops out easy when you have stripped callipers down.
marty400
Oh right, I thought 10 and 13 would be all one piece of metal!
I had a look - bott parts are there....
Any suggestions on what I should look at, when I take the caliper apart on Sat?
Martin
Martin
- leopard_pagan
if its a NC29.. use the pic as a reference to see if anythings missing.
i have NC23 brake break down if you need it
PM me
PM me
