Just Started a 3TJ Full Rebuild
Posted: Sun Jan 30, 2011 6:46 pm
I just dug out a 3TJ that's been sitting in my lock up for about 5 years, looked a bit rough at first but came up OK after a clean. It's going to get a full strip down and rebuild over the next couple of months and I'll put some photo's on as I go.
If there's anything anyone wants a pic of while I'm working on it let me know as most things will be apart at some point.
It looks OK up to now, almost everything is there including all original bodywork, good downpipes and what seems to be a shock with damping (which was a shock). The forks have a bit of surface rust on the inner stanction so they'll be comming apart and may need replacing.
Things I need at the moment are:
Generator cover
Water pump cover
Screen brace - Got it!
Screen
Right hand clip on - Got it!
Rear light surround
If anyone has any of the above PM me!
The bike as I found it:
A bit of a clean and some bits removed:
Generator cover
Water pump cover
Screen
Rear light surround
