FZR400 - It did run now it won't start -Nearly fixed-
Posted: Sun Jan 30, 2011 1:57 pm
				I've read through most of the posts in the workshop about starting problems and tried to start my bike but no joy.
I've got an '88 FZR400 engined bike that I bought a couple of weeks ago. It started fine when I checked it out and was started with no problems through the first week, although only stationary. I rode it last weekend, all of 5 miles, with no worries. Yesterday I went to go for a run and it wouldn't start. When I sat the bike up, fuel started pi**ing out onto the floor. I removed the tank cover and lifted the tank to find this -
New fuel hoses and clips fitted, connected the tank, and tried to start it again. No joy not even a cough.
I pulled the hose off the carbs from the fuel pump then switched on the ignition. The pump started working and fuel flowed into a bottle at a reasonable rate. Connected the hose back onto the carbs and switched the ignition on again. The pump ticked for a while then stopped, as I expected, when it got to pressure.
I then removed the airbox to have a look into the carbs, etc. Nothing seems wrong from first inspections. Choke and throttle operating correctly. although saying this I don't have much experience with bike carbs.
I managed to get a plug out. It seemed in OK condition and appeared wet. This was not as easy as it sounds.
I checked the spark and there is one, but didn't seem too strong.
I checked the exup valve and it's slightly out of line. I tried adjusting it as much as I can but cable 2 has some slack I can't adjust out and the alignment marks are still slightly out although better.
I plan on going out to get some easy start and try that, squirting it in the carbs, just to check. Also, I'll order some new plugs and wait for them to arrive.
Any other forum suggestions from you knowledgeable guys.
I initially thought it was a fueling problem, as the initial fault was the fuel line. I'm starting to suspect the ignition system now. BTW, I expected to have to fix some problems on the bike as it's 22 years old, so it's not a problem, just a set back.
edit - title changed
