GK76a Cam timing and clearances
deacfo
Post by deacfo »
Just thought I'd give an update.
I used the timing information from my GK73a manual and bugger me if it doesn't work for the GK76a. Obviously there are more cam followers to deal with but apart from that the timing marks and cam positions are identical. Hope this helps someone.
Craig
Hi,
Can anyone help out and send me the info required to set the cam timing and valve clarances please on a 1990 GK76a (including links between cam sprockets). I have the info for my GK73a but obviously it doesn't transfer to the GK76a very well!
Craig
Variablevalves suck
Re: GK76a Cam timing and clearances
Post by Variablevalves suck »
Hi Craig,
The clearences are in the sticky up top but ive lost the 76a pdf so am unable to help with the cam setting. I should think with a liitle thought you will be able to work it out.
