disc bolts loctite or not
Posted: Thu Jan 20, 2011 1:25 am
by bobthebike
about to change my front discs, just read article in MCN about this and they say to use loctite. But in my haynes manual it says nothing about loctite. Anyone got any opinions?
Re: disc bolts loctite or not
Posted: Thu Jan 20, 2011 1:47 am
by Cammo
I don't like using it. I've snapped disc bolts when tightening them before because of loctite residue on them.
You'll never see Honda advising to use loctite on disc bolts. Just torque them up to the required spec.
Posted: Thu Jan 20, 2011 1:53 am
by Morespeedvicar
Some people do some dont. i never have, but i like to be able to get again them out fairly easy. Never had any work loose either! Just make sure there torqued up right.
Prob doesnt help sorry.
Ian
Posted: Thu Jan 20, 2011 1:56 am
by bobthebike
Thanks for that. I thought this might be the case
Posted: Thu Jan 20, 2011 3:41 am
by Cru Jones
I don't like to Loctite mine because the steel bolts always seem to galvanize in the wheel and are tough enough to get out. Honda makes some bolts that are pre-drilled for safety wire and that's what I do on my RS125, but then again I'm paranoid. :oops:
Posted: Thu Jan 20, 2011 9:48 am
by banoffee
I don't but check them from time to time as part of normal 'going over' the bike. I *hate* removing old ones :x
Posted: Thu Jan 20, 2011 3:49 pm
by porndoguk
rear discs i use Nyloc nuts,
fronts just adequatly torqued.
