Need new valves, where can I buy them? GK73A
- Bike owned: GSX-R 400 GK73A
- Location: Bridge of weir (About 15 miles West of Glasgow)
hey guys, i cant seem to find a set of valves for my gk73a I theorise they could be the problem with my first and second cylinder, and even if they're not, i should replace them anyway.
HALP!
i've tryed ebay, froogle, google, etc etc and came up with a full wallet :/
HALP!
- Variablevalves suck
Re: Need new valves, where can I buy them? GK73A
What is making you think that you need valves?
cylinders 1 and 2 on bike arent functioning correctly despite having a spark, fuel and air... i can have it as a guess to be either cam timing, gasket leak or damaged valves although I haven't ruled out the possibility of a cracked head, there's no oil leak when i start it up through the cylinder which would rule out scoring within the cylinders and / or damaged piston rings.
although if you have any ideas i'd appreciate it.
- Bike owned: R1x2 98/2k/Gp125/73a/76a/76a
Have a leak down test to determine if there is a problem or if you cant/wont do that take the head of and have a look.It will cost you a head gasket/time but at least you`ll know.....
Andy
Andy
- 4hundread
- Bike owned: 91 GSXR 400
