NC35 fairings on NC30
- uber pikey
Simple question,
does the NC35 fairings fit onto the NC30 and vice versa?
I know the obvious head light shape, but what about the alignment and fittings?
I saw it so I took it!
- force-v4
Re: NC35 fairings on NC30
Yes, it has been done may times but you cant use the tank with-out modification as far as im aware. and you'll need the main front mount & mirror brace & also an rvf subframe.
- uber pikey
Are the lower fairings interchangable? Can you fit the lower fairings to the nose cone of either model?
- BillingCBR
Belly pan, yes, but not the middle panels, the vents are different (RVF ones are deeper I think) but from what I remember you can use either lowers, the mids from the base bike and either upper as long as you have the screen brace and headlight bracket
- micpec
Yack on here done it long time ago. There is more to be found with search button. Not sure if Yacks bike is somewhere on here. I remember not to forget the 2 x lower NC35 subframe bolts that holds the RVF rear seat panels on.
- uber pikey
i just bought a set of 35's on fleabay and will either try and make it fit without the nose cone or just try and swap it for NC30 bits what do you think?
- force-v4
It'll go on, you now just need the brackets etc.
Depends if you like the 35 look or want to keep it 30?
- uber pikey
I actually want to keep it 30, so I will either sell the extras and use the money to buy or swap for the bits I want. I just need to get them delivered so I can check their condition. I might be tempted to convert the rear tail unit but not for a while.
- uber pikey
- BillingCBR
Did you get a mudguard with the panels? If it's any good and you want to get rid, let me know
