air box removal gk76 with tps
hi all whats the best way of getting the air box out the way , so i can remove and clean the carbs and reset them.
or any idears runs only on choke and wont rev over 4000 rpm but will do onice it ya leave it ticking over for a bit then dies , wont tick over eaither.. cheers for ya help
- Bike owned: R1x2 98/2k/Gp125/73a/76a/76a
Re: air box removal gk76 with tps
Hello mate,madmatt1969 wrote:hi all whats the best way of getting the air box out the way , so i can remove and clean the carbs and reset them.
Remove seat/battery/rear of the airbox and filter. Remove the steel clips on the airbox holding the rubbers between the airbox and carbs,loosen the screws holding the rubbers to the back of the carbs and pull the rubbers through the inside of the airbox and put to one side...you are then free to undo the inlet retaining clips and remove the carbs out the side of the bike. Only after you`ve removed the choke/throttle cable` and unplugged the TPS lead...
As for running only on choke sounds strange(airleak possibly?),Is there a lot of smoke ie black(unburnt fuel),How long is it since they were last stripped/serviced? How old are the plugs? Are the leads all good with a nice fat spark at each plug? Chances are the `o` rings will be past their best so will need replacing (forum member variable valves will sort that for you),good luck,let us know how you go
Andy
cheers andy ..
just bought it fitted new plugs ,,yer it does smoke running rich . doing me sweed in lol
cheers for the advise dude ,will get back outside in the cold and get going on stripping the air box out lol
thanx again mate
thanx again mate
Hey,madmatt1969 wrote:cheers andy ..
cheers for the advise dude ,will get back outside in the cold and get going on stripping the air box out lol![]()
thanx again mate
Did you sort that 76 out or are you still having trouble with it?
Andy
