Porndoguk's SEED NC30
Posted: Mon Jan 03, 2011 10:37 am
Before: The pic of the bike in the piston heads advert
After: (Sept 2012) more been done since :s
EDIT: October 2012
alot of pics for the first 10 pages or so (the facebook ones) the links have died,
i have saved the pics onto photobucket but trying to remember the orders they went and where they went was tricky and ive spent 3 hours rearanging them for your viewing pleasure.
the direct links to the 2 albums that were once on facebook are here, there are alot of pics missing from this thread that are on there though. Rick
Album 1
http://s107.photobucket.com/albums/m302 ... My%20Bike/
Album 2
http://s107.photobucket.com/albums/m302 ... 0Bike%202/
All Powder Coating done by Marmo Coatings - Rugeley
Full Stainless Steel / Titanium Bolt & Nut fixings ALL replaced.
Specs List - From Front to Back
Bridgestone BT090 Tyre,
Powder Coated (HRC) Gold,
Captive Stainless Wheel Spacers,
Crash Bungs Fork Bottoms (Coyote Moto)
Arashi Wavy Discs (Rick O)
VTR1000 SP1 Calipers, Stainless Bolts
Rick O Caliper Brackets, Titanium Mount Bolts
EBC HH Pads
Stainless Steel Banjos, Bleed Bolts
Goodridge Stainless Steel Braided Hoses, (DIY)
Fork Internals, (Rick O)
Polished/Brush Alloy Fork Lowers, With CBR600F Stanchion Protectors
Carbon Fibre Front Fender, with OEM Mounts Rivited
UK 5w Osram Sidelight Bulbs,
UK H4 Osram Headlight Bulbs,
20A Headlight Relay,
MPH Custom Dial, (Lockwood)
100mm Sprint Steering Damper (Reverse Fitted), With 41mm Stanchion Clamp
Custom/Adjustable Lockstops
Yokes Fitted with A2 Stainless Bolts, Upper Drilled & tapped for M10
HRC Stem Bung
Alloy Yoke Nut (Tyga)
Alloy Lightweight Handles (Rick O)
Renthal Pro Grip
Adjustable Brake & Clutch Levers
Q/A Throttle
CBR900 5/8" Master Cylinder
Samco Hoses
Crash Bungs (Coyote Moto)
Crash Adaptor Plates (Kayla - Projection)
Full Tyga Sprung Stainless Steel Exhaust - 440mm Carbon Can
NGK Replacement HT Leads (Rick O)
PiperX Crank Breather
Carbs
125 Front 125 Rear
#35 Pilot Jets - Pilot Screws 2.1/4 turns
Float Heights - 6.8mm
Brass Needles (Rick O) - Soon to be fitted fully adjustable Factory Pro Titanium Needles
No Shims Fitted
NC24 Slides - 2.5mm Vac Hole
K&N Panel Filter
Tyga Carbon Lid
HRC Feeder Tray
HRC Fuel Tap Mod
Alcantara Seat Recovering Rider & Pillion
BMW S1000RR Shock
D.Faulkner Spring 800lb
R&G Shock Tube
Tyga Rear Sets
SES Toe & Foot Pegs
Alloy Height Adjustment Plates
Titanium Shift Rod
Polished/Brushed OEM Exhaust Hanger with Alloy Spacers
Carbon Fiber Rear Hugger & Chain Guard
RK Chain 520 Pitch
Renthal 15T x 40T 520
Torque Arm Spacers (Kayla - Projection)
Goodridge Stainless Steel Braided Hose - Through Swingarm
Arashi Wavy Rear Disc
Shark Fin (Rick O)
Carbon Exhaust Hanger
Solo Seat Cover (Sprayed By Drunkn Munky)
Ignitech CDI Ignition Module
Titanium Wheel Nut (Kayla - Projection)
Titanium Hub Nut (Kayla - Projection)
Titanium Pinch Bolt (Kayla - Projection)
Alloy wheel Spacer & Stainless R CLip Pin
Powder Coated Rear Wheel (HRC) Gold
Bridgestone BT090
I guess its about time i started my own thread with pics and all that ive done so far, its gone like a blur when i actually think back to what ive done and spent on the bike itself. id like to make this like a diary as such so i and others can keep up with its history and progress.
I bought the bike on Sunday June 13th 2010 from a guy in bridgenorth who had listed it on pistonheads, i paid a rather overly priced £850 for an F Reg Grey Import in cosmetically good condition (Crappy fiberglass Fairings) but mechanically unstable and unclean, he was a farmer and just getting to his house in the van was tricky without contemplating on a daily ride up and down that driveway. it had Stainless Steel braided front hoses which had alloy banjos, which i was informed by my mate were an MOT FAIL
also the rear BT090 was dangerously low, still legal but low, so i haggled him from £900 to £850, without knowing the tyre would have cost me £120! on our way home (20 Miles) the bike broke down/cut out 3 times down to a fueling problem that we put down to the carbs or vacuum hose. ill continue this in my next post.
I'd been searching for a short while and went through several options before deciding on an NC30, i had it in my silly little head my first bike when completeing my direct access was going to be a Ducati 748. before i settled for a VFR i contemplated on HONDA XR250!
I'd been riding from the young age of 4 I think and then all the way into my teens, then had a road legal yamaha DT50 at 16, when i turned 17 i had me a 1995 RS125RE with a rotax 127 engine, then went to college got stuck into my carrier, bought a car did my driving and then December 2009 dad asked me what i wanted for christmas and i said my bike licence, it cost me £750 odd quid to obtain! passed first time of course on Monday 14th of June 2010.
EDIT: October 2012
Album 1
Album 2
EBC HH Pads
HRC Stem Bung
Renthal Pro Grip
Q/A Throttle
Samco Hoses
Carbs
125 Front 125 Rear
No Shims Fitted
K&N Panel Filter
Tyga Carbon Lid
HRC Feeder Tray
HRC Fuel Tap Mod
BMW S1000RR Shock
R&G Shock Tube
Tyga Rear Sets
SES Toe & Foot Pegs
Titanium Shift Rod
RK Chain 520 Pitch
Shark Fin (Rick O)
Bridgestone BT090
