CB1000 LHD Switchgear Similar or Same to NC30?
- tanto
Despite strip, clean, & re-assembly, my LHD switchgear appears to be worn out. The little ball bearing inside the unit jams & refuses to allow the indicator selector to select "left". "Right" is okay.
A quick scout around and I see a LHD switchgear unit on eBay.co.uk that may be compatible (assuming one re-wires its' plugs):
http://cgi.ebay.co.uk/HONDA-CB-1000-201 ... 3a60385f23
Item number Item number: 250722410275.
Would this CB1000 unit work on an NC30? Is it the same? It *looks* very close.
- CRM
Re: CB1000 LHD Switchgear Similar or Same to NC30?
plugs are differerent, but this is alot cheaper. you could just use the case and insides
http://cgi.ebay.co.uk/HONDA-VTR1000-FIR ... _500wt_922
- tanto
If the CB1000 unit is identical to the NC30, and current production, I could order it in Thailand. Might be a bit less expensive here too, and new switchgear would look great when the yokes, fittings, & bars have been powder-coated.
As the picture doesn't show the entire unit, can anyone confirm that the CB1000 LHD switchgear is identical to the NC30's? I'm not worried about re-wiring the plugs.
