Page 1 of 2
Project NC(insert number here)
Posted: Mon Dec 13, 2010 9:59 pm
by thunderace
OK, so I've now got almost a complete NC24 in spares. However, I want a challenge and I want to build something unique but tasteful. I think a 400 engine will be a bit tame (plus the NC24 exhaust presents issues in the wallet department).
So give me some ideas guys?
What engines will physically fit into the 24 frame? Will an 893 or 918 Blade engine fit?
Or am I better looking for a V configuration engine?
Re: Project NC(insert number here)
Posted: Mon Dec 13, 2010 10:26 pm
by Smev
Or what about a big single? - supermono stylee!!!
Posted: Tue Dec 14, 2010 8:13 pm
by Dgeoff33
SV1000
Posted: Tue Dec 14, 2010 8:25 pm
by force-v4
VTR1000 firestorm lump - not expensive & plenty of spares plus, its a honda!
I doubt you'll get a in-line 4 in the V4 frame.
Posted: Sun Dec 19, 2010 2:31 pm
by Bumder
Will the SV100 or VTR lump fit in the NC30, if so is it a lot of work.
Posted: Sun Dec 19, 2010 3:00 pm
by Drunkn Munky
Bumder wrote:Will the SV100 or VTR lump fit in the NC30, if so is it a lot of work.
Try it and let us know
SV 650 lumps go but some have tried and gave up so it cant be that easy, any engine that will physically fit will work but thats just the start of it. I reckon if the SV100 or VTR lump fitted you would end up with the fuel tank under the seat. It would then most likely shake itself to a slow death with questionable handling
If it were me id go, SP1 frame, VFR800 engine, RC45 bodywork. Job done
Posted: Sun Dec 19, 2010 4:51 pm
by thunderace
I'm thinking I may be adventurous here and try building a reverse trike, Can-Am style, seeing as I have the rear end all sorted. Plus a reverse trike is more stable anyway.
I'm thinking along the lines of an Africa Twin or Yammie Virago 535 or 750 lump.
Posted: Mon Dec 20, 2010 12:00 pm
by thunderace
Think I'll be scrapping the other engine idea having looked to see what they are selling for
I might just use the spare 400 lump I've got. I also thought, to get around the exhaust issue with the 24, that I would greate a 4x 1-1 system with the rear two exiting the rear seat cowl, RD500 styleeeeeee
Posted: Tue Dec 21, 2010 2:25 pm
For a trike or something the 24 frame would be ok, especially if it's knocking around doing nothing.
Something i'd like to do given enough time would be a HRC 24 engine in a 35 frame with the HRC exh system (remade in TI not mild-steel) would be pretty awesome.
It'd kick out circa 75hp, have decent gearing and have the tyre / frame / forks advantage of the later NC's :)
From this with crossply and bouncy 37mm forks and sliding calipers
To this with 17" radials, 4 pot calipers and 41mm forks.
Even without the power increase the laptimes would come down..
Plus it'd be quite unique
Done well in a decent retro scheme
picture courtesy of Cammo...
Then throw loads of money at it getting it to 80's spec (85bhp, 113kg)
Interesting fact... that bike above is an evolution of what the 24 was based on :-)
This is where the 24 gets its design from
Posted: Tue Dec 21, 2010 2:37 pm
by thunderace
