headlight bulbs
Harveyb
headlight bulbs
Post by Harveyb »
My 2TK has 3 pin 35/35w headlight bulbs fitted, same fitment as a standard car bulb H4.
If I change the standard bulbs for the higher wattage car bulbs will it cause problems? I'm just thinking about replacements as i can't seem to find the 35/35w bulbs for sale anywhere.
thunderace
Bike owned: R6, YZF600R
Re: headlight bulbs
Post by thunderace »
35/35w bulbs aren't quite the same fitment as H4. On the H4 there are two tabs sticking out that will need to be flattened :peace:
BTW, you may need to change the fuse to a 15A for twin headlights but the loom should be plenty up to the job :mrgreen:
Re: headlight bulbs
Post by Evilchicken0 »
You might have had the lamps replaced for some Yamaha UK ones, in which case they'd take H4's. The standard FZ600 lights were 35/35watt (sad that I remember that far back, huh), so you could probably find them at a bike shop. I put in standard car bulbs and it was ok ...
I fitted 55/60's into my Bimota and the wiring sheaths went hard over the space of 18months then the wires broke so I'd have to advise you to fit lighting relays.
thunderace
Re: headlight bulbs
Evilchicken0 wrote:I'd have to advise you to fit lighting relays.
The headlight circuit is already relayed. You issues were due to the heat generated, not a direct cause from the extra current flow so extra relays is a waste of time.
If you think heat may be an issue, fit a small PC fan around the headlight cluster.
IN fact, OP, I think I may have some 35/35w bulbs if you want them? PM me your address and I'll post them out when/if I find them.
Re: headlight bulbs
The "heat" is generated in the wire due the current draw of the bigger capacity bulbs. The relays were fitted by a garage and since then there's been no issue.
Harveyb
Re: headlight bulbs
Post by Harveyb »
I took my 2TK out today and came home in the dark. I'd forgotten how crap the standard headlights are. I managed to find some 45/45 headlight bulbs on ebay that are the same fitment, maybe they'll improve things a bit. They should be ok with the standard 10A fuse. I'm not keen on going for 55/60 bulbs, upping the fuse to 15A is one thing but I can't be bothered with adding relays
