Making standard rearsets look decent?
- silentRVF
- Bike owned: NC35
Hey guys,
Any tips to freshen up the original rearsets on an NC35? I'm going to give them a good polish with some Autosol.
I've also seen a picture where someone has done an average job of drilling holes in them..
Has anyone seen a good example of this being done successfully? Pics?
- Hadies
Re: Making standard rearsets look decent?
http://i207.photobucket.com/albums/bb73 ... 010488.jpg
A bit like that? Thats from BillingCBR's thread. Looks pretty good. Would polish up really nice.
- superlite
- Bike owned: TLS, LB80 x 2
You'll need to remove the coating off them before you get the Autosol onto them. Caustic (oven cleaner) works a treat and then it doesn't take much elbow grease to give them a mirror shine by hand - or 5 minutes on a bench grinder with mopsjonno92 wrote:Any tips to freshen up the original rearsets on an NC35? I'm going to give them a good polish with some Autosol. Cheers
Personally not a fan of drilled rearsets, but if you do it, drill a pilot hole first (or make up a jig). It looks awful if they're even a little bit out of whack!
'Take it to the Back'
veefer400
Try these - on my NC23 but same thing...
http://i109.photobucket.com/albums/n61/ ... C04490.jpg
http://i109.photobucket.com/albums/n61/ ... C04491.jpg
- craigs23
- Bike owned: Quite a few
I used some scouring pads with a bit of paraffin, then with wire wool a dab of brasso, finished with a smearing of ACF50 (not to mention a little patience). Nice smooth, O.E. finish; not keen on polishing too much these days (apart from the bolts holding the things together).
Might help to get a good base for polishing if you must, I recommend sorting any drilling out before you start on the restoration mind.
- silentRVF
- Bike owned: NC35
Wow that looks very schmick!! Cheers for the advice.
CammyGTIR
If I can offer an opinion Jonno, BEET ones look quite good, unless you're staying stock?
- silentRVF
- Bike owned: NC35
Thanks Cammy. I'd love to but I'm already spending enough on the bike.
If a cheap set of aftermarket ones come up on eBay or here though, I won't say no
Quo Vadas
- Bike owned: 2 x RVF400
I might have a set of WRC rearsets soon as I have procured another RVF. I'm pulling apart bikes at the moment and swapping some stuff over. I'm a bit over 6ft and find that the WRC rearsets cramp me up too much. I prefer the stock.jonno92 wrote:Thanks Cammy. I'd love to but I'm already spending enough on the bike.
I'll let you know mate.
Quo Vadas
They have come up unbelievable!!guess who wrote:I used some scouring pads with a bit of paraffin, then with wire wool a dab of brasso, finished with a smearing of ACF50 (not to mention a little patience). Nice smooth, O.E. finish; not keen on polishing too much these days (apart from the bolts holding the things together).
