GK76A Shock?
GK76A Shock?
I was hoping someone on the board might be able to identify this as a shock off a GK76 or not. Mine is a standard 1990 model so it did not come with a shock with a remote resevoir. All the shocks I've seen off GSXR400R's have a black nob to adjust on the remote resevoir. Mine has a slot for a screwdriver. It also has 0D1 at the top of the shock.
- monkers
- Bike owned: GSXR400R
Re: GK76A Shock?
My '92 has a shock with a remote reservoir. Not sure if that is one just by your picture. I'll have a look at mine later today if no one else comes back to you.
There are no secrets, you either know it or you don't.
- Bike owned: GK76SP & ER6F
Re: GK76A Shock?
Looks a lot like my '92 SP, but I can't be sure. It certainly looks like it's in good condition though.
- monkers
Re: GK76A Shock?
Mine says 2-6H at the top. Do you know where this one came from? Might have a clue on the spring value then, no point if it came from 750 or 1000 gixxer, too stiff.
Re: GK76A Shock?
No, the owner I purchased the bike from had zero information on the bike. Is your bike a 1990 model? I did happen to find a 400 for sale in Japan that atleast has the same remote resevoir as mine. First one I've seen like mine. Is this possibly the way the 1990 remote resevoirs where? Although, the bike in the picture is not a 1990 SP unless it was repainted.
- monkers
Re: GK76A Shock?
Mine is a '92, it's not a SP model. If you look here: http://www.suzukicycles.org/All-Suzuki/ ... odels.html
You will see that 1990 SP did indeed have a remote reservoir and that in 1991 it became standard kit. Here is a pic of my tail section.
HTH
HTH
Re: GK76A Shock?
Yeah, that is what I guess I'm looking for. Does anyone have a 1990 SP or a picture of a 1990 SP's shock/remote resevoir so I can see if it matches mine (slot for screw driver vs black nob).
- Bike owned: RSV Mille Road, GSXR400 Track
Re: GK76A Shock?
If you PM me your email ad I'll send you a pic of the 1990 SP I used to have. Don't have a close up of the resevoir I'm afraid but it may help.rgvsp wrote:Yeah, that is what I guess I'm looking for. Does anyone have a 1990 SP or a picture of a 1990 SP's shock/remote resevoir so I can see if it matches mine (slot for screw driver vs black nob).
Re: GK76A Shock?
The 1990SP has a black dial for adjustment.
Re: GK76A Shock?
Yes mine does.... 1990 ^^^vivo wrote:The 1990SP has a black dial for adjustment.
