Aluminium foil on fairings
chownsy
Bike owned: KS125, ER5,VFR400 NC24
Post by chownsy »
I remember seeing ages ago on a set of fairings someone had stuck aluminium foil to the inside of them to help keep the plastic cool and stop the paint cracking from the engine heat.
A roll of foil is cheap, would you advise doing this to my fairings to help improve there life?
CRM
Admin NWAA
Admin NWAA
Re: Aluminium foil on fairings
Post by CRM »
its a bi thicker than domestic foil. more like the self stick stuff used to joint plasterboard.
chownsy
Post by chownsy »
CRM wrote:its a bi thicker than domestic foil. more like the self stick stuff used to joint plasterboard.
I wish i had thought about it before, i could have nicked all the off cuts from the days i worked at marcus sportcars
That silver stick on insulation foil they sell in B&Q or wickes should do the trick
chownsy
Post by chownsy »
Drunkn Munky wrote:That silver stick on insulation foil they sell in B&Q or wickes should do the trick
Rightio then, ill have a looksie in there trade catalogue
In screw fix they have Radiator Reflector foil but it has to be glued on :(
We used to use contact adeshive on the car chassis with the heat proof material and then taped the edges.
If i can find the foil tape then i could do the same on this with the reflector stuff as its only £7 for 5m
Let me know what you decide on as i need to do the fairings on my gsxr before any more paint bubbles up after the so called dream machine didnt refit the heat protection when it was painted :down:
chownsy
Post by chownsy »
Drunkn Munky wrote:Let me know what you decide on as i need to do the fairings on my gsxr before any more paint bubbles up after the so called dream machine didnt refit the heat protection when it was painted :down:
Just priced it up just under £20 for it, so going to do it and save money having to repaint the paintwork from heat damage.
Screwfix numbers:
35529 - £9.35 - tape
10612 - £6.86 - rad insulation
51081 - £2.99 - adhesive
porndoguk
Post by porndoguk »
Screwfix numbers:
hold your horses kiddo i have some self adhesive foil/insul tape used for pipe laggin,
let me know how much you need and ill dig you some out,
chownsy
Post by chownsy »
ideally i need to do both side fairings as i dont want my paintwork getting damaged from the heat off the engine.
and thanks for the offer :grin:
porndoguk
Post by porndoguk »
chownsy wrote:ideally i need to do both side fairings as i dont want my paintwork getting damaged from the heat off the engine.
its the £8.99 thingy youve looked at screwfix,
i have posibly about 10m going spare which should see you fit?
