What is the wheel bearing size?
PARUS
Just need to know front/rear wheel bearing size.
stimpy
Re: What is the wheel bearing size?
do u want the dimensions of the bearings or the product code.....?
stimpy
stimpy
PARUS
Better to have both.
One of guys here asked me about bearing dimensions or product code, but I can't find it in Haynes manual.
When I had changed bearing, I just take them out, came to shop and order with same dimension produced by SKF
- Sligeach
are they the same as the VFR front wheel bearings
if so i have come brand new ones so i can get some dimensions for ya, measuring with a vernier calipers
stimpy
6004 is the product code,its the same front and rear.
it will be stamped on the old bearings
....that is,if you have the old bearings
i have new bearings loose,but my verniers are at work,
so cant measure them up for you
stimpy
stimpy
