help!!!!
Landy63
help!!!!
just a quick one, does anyone make a replacement rear hub/axel nut? and also how chuffin big is it? also where can i find a new chain adjuster wheel thingy because mine is chewed to pieces.
Damien
Damien
mick.mh2racing
Re: help!!!!
Don't know where you'll get another nut from but you'll need a 36mm socket for it. If you take off the hub and file all the teeth back to sqaure, is as good as you're going to get or need. Most bikes will have some damage having butchered by screw drivers over the last 18 years. It's fairly soft aluminium so to file it square is fairly easy.
How hard can it be?
Landy63
Re: help!!!!
ey up mick,
i tried a 36mm socket today and it was too small
? I recieved your parcel this morning, though thanks for sending it through mate. as soon as i get the axel nut off have ago at re-profiling the chain adjuster but untill then im not sure what to do lol
damien
damien
wullvfr
- Bike owned: zx9r c1
Re: help!!!!
the hub nut is 46mm........the wheel nut is 36mm... :D :D
Landy63
Re: help!!!!
ha ha makes sense, but im having trouble finding somewhere that sells a socket above 38mm? even went to machine mart toady :) thanks for the info though mate
Damien
Damien
mick.mh2racing
Re: help!!!!
Hi Damien, honestly to file the teeth square is easy. Sorry, yes to get the wheel off is 36mm and the nut on the opposite side is 46mm. Got both sizes if you need a borrow. Or drop your swing arm off here and we'll strip it down.
How hard can it be?
wullvfr
Re: help!!!!
tool shop direct does 46mm sockets and for under a tenner...BARGAIN!!!!!
thats where i got mine :D :D
Landy63
Re: help!!!!
your not wrong cheapest i could find was 14.99 off flea bay, thanks again mate
