Battery options - small, powerful and gel?
Posted: Fri Jul 11, 2008 8:57 pm
				I've seriously hacked my FZR400 3en2 subframe about to take a 98 r6 seat unit.  Now I've got to find some where to cradle a battery.  Under the rider seat on it's side with the terminals facing the back of the bike or facing the right hand side of the bike as you ride it is looking like the best plan - although space is limited as the hump on my custom under tray takes some of the space away under the seat/fairing.
Does any have any advice or recommendations on a small gel battery with plenty of power. I'll be going with a set of taylor leads and ignition, I just want to put something small, but with good kick in, so I don't get loads of starting problems or flat batteries after a couple of tries. I don't really know what to look for in term of a base spec, although compact is a must!
- I'd go with a kick start if I had feet like frankenstein and leg muscles like Clarke Kent!
Sadly I've got a face like frankenstein's arse hole and a hair cut like Clarke Kent, neither of which are helping right now. :D
