nc30 wheelie
nc30 wheelie
i'v e been out on my nc30 (VFR400) this morning and got a little bit brave and had a go at a wheelie.
after approx 10 attempts, the highest i managed 2 get the front wheel was approx 1foot of the ground.
My techniquie was to roll at 4000rpm in first the wind throttle on and slip clutch. is this correct or is it a recipey 4 disaster??
Re: nc30 wheelie
can you wheelie on a bicycle?
id start there to get your ballance, as it could be a recipe for disaster if youve never done it before,
also if you do get lift off, never do it for periods of more than say 20secs as the oil will sink to the rear of the sump and the pistons will not get the lubrication, youll end up burning the engine up or seizing it.
- Bike owned: KS125, ER5,VFR400 NC24
Re: nc30 wheelie
rickyb_dj wrote:can you wheelie on a bicycle?
also when you return it back down, do it gently, if you do it hard you can twist frames or buckle things in the worst case.
Re: nc30 wheelie
yeah i forgot to say that!chownsy wrote:rickyb_dj wrote:can you wheelie on a bicycle?
Re: nc30 wheelie
Woohoo my first ever +1 :Drickyb_dj wrote:yeah i forgot to say that!chownsy wrote:rickyb_dj wrote:can you wheelie on a bicycle?
- Bike owned: VFR400 (91) CB900 (2008)
Re: nc30 wheelie
More of a trick for MX bikes really but if you must keep a toe on the back brake. Once it's up, if it's going over backwards a dab on the brake will bring the nose down. As above, when letting it down, give it plenty of throttle before it hits the deck which will reduce the impact.
It's risky though. Get it wrong and it'll end in tears. If you want to learn some good skills, take it on the track. That's where it was always meant to be.
Re: nc30 wheelie
cheers. would increasing rpm help to lift it higher??
Re: nc30 wheelie
lazyboydobby wrote:cheers. would increasing rpm help to lift it higher??
to control a wheely:
increaseing revs/more bite on clutch = higher,
decreasing revs/mre slip on clutch = lower
emergency lowering of bike (say it was going over backwards) = lightly apply rear brake
I never ever ever wheely but a mate told me how to control one if i wanted to do it
- alexwitham
Re: nc30 wheelie
If you want it to pop up easier, drop the gearing to 14f/42r.
Re: nc30 wheelie
Nc's are in no way powerfull enough to get the front up properly, your be replacing forks seals constantly or at worse do more serious damage.
